Where to get info on Trans swap
Old Dec 5, 2007 | 05:56 PM
mopar99's Avatar
mopar99
Default Where to get info on Trans swap
I know its probably been posted a dozen times but my auto trans is going out from sitting to long and id like to make it a 5spd.When i get a 5spd parts car what doi all need to swap between the two. If you guys could point me in the direction where the info is to swapitid really appretiate it.
Old Dec 5, 2007 | 09:07 PM
mr340's Avatar
mr340
Muscle Car Moderator
Default RE: Where to get info on Trans swap
From here: https://dodgeforum.com/m_530310/tm.htm
Q: Can I swap in a manual transmission into my automatic and is it worth it?
A: Yes you can and will need the transmission, shifter, brackets, shifter linkage cables, passenger side axle, an MTX PCM, and a few other miscellaneous items. Best way would be to have a donor car readily available. Yes, it is definitely worth it!
This was easy to find too....
Complete how-to with pics...
http://www.msu.edu/~lareseer/trannySwap.html
Old Dec 5, 2007 | 10:06 PM
mopar99's Avatar
mopar99
Now on his list he opted fora 2000, cable actuated, 3.55 w/ .81 5th, would it be better to go with that trans or one out of a mid ninty's model neon
