ATX TB & CEL
i swapped to an atx tb on my mtx. after about 100-200 miles or so I would geta CEL that came back as the throttle posistioning sensor reading the wrong voltage. my battery went bad a few days later. the car would only drift start (had to park strategically till i could get another battery.)
dunno if the battery had anything to do witht the CEL or not. but i swapped the battery. the light went away, but just like before 100-200 miles later got the CEL again w/ the same code. but the car started just fine after that.
bought the tb on ebay and it didnt have cruise. so a couple of 1hr and a half trips to college later (every tuesday and thursday) i got sick of the CEL and not having cruise control. and switched my tb back to the original.
CEL went out around 100-200 miles later and has stayed off since. sucks not having the power, and im pretty sure i could add the cruise piece to the other tb, but is there something screwed up with it that it gives me a CEL?
you can also remove the throttle shaft form your MTX with CC and swap it to the ATX one so you can hook up your Cruse control. i belive you have to remove a snap ring from under the TPS sensor the two screws from the throttle valve and swap the shafts
stuff on throttle springs
https://dodgeforum.com/m_954020/tm.htm
