fuel cell
Old Dec 14, 2007 | 11:12 AM
hatchetman2590's Avatar
hatchetman2590
Default fuel cell
if i were to remove my stock tank and then install a racing cell could i run new wires and just bypass the fuse boxes and just install a inline fuse?
Old Dec 14, 2007 | 06:25 PM
hatchetman2590
Default RE: fuel cell
hello?
Old Dec 14, 2007 | 07:19 PM
12 volt's Avatar
12 volt
That would work. but you would have to install a switch to turn the fuel pump on and off oruse the OEM wiring
Old Dec 14, 2007 | 07:30 PM
hatchetman2590
well i could go str8 from the battery to a toggle switch and rite b4 i turn the key i can turn it on i guess rite?
Old Dec 14, 2007 | 07:46 PM
12 volt's Avatar
12 volt
yeah, it could be your ant-theft
Old Dec 14, 2007 | 09:34 PM
hatchetman2590
that and its cool to be hitting switches wen u start ur car
Old Dec 14, 2007 | 10:34 PM
bone33's Avatar
bone33
where i live, that wont pass the emmissions laws, unless you are going to somehow plumb new canister lines into that fuel cell. check your state laws. other than that it will work
Old Dec 15, 2007 | 08:49 AM
hatchetman2590
well the one with the fuel cel is going to the drag strip so it aint street legal anyways but thanx for the heads up anyways
Old Dec 17, 2007 | 12:54 PM
spudsterier's Avatar
spudsterier
i have my external fuel pump hooked up to a toggle switch straight from the battery.....all i do is flip the switch when the car starts.....otherwise it wont have enough fuel to run boost
Old Dec 17, 2007 | 01:51 PM
hatchetman2590
oh ok well does a efc come with a fuel pump? if not can i use my stock one
