Turbo fuel rail Q
Old Dec 22, 2007 | 10:07 PM
I_Ride_Neon's Avatar
I_Ride_Neon
Default Turbo fuel rail Q
Where can find a fitting for the return line its 7/16 20. I looked everywhere. Another thing is i can use my stock injectors right? What should i set the fpr at?
Old Dec 23, 2007 | 12:09 AM
95to96transplantneon's Avatar
Default RE: Turbo fuel rail Q
if you are using the stock fuel rail and the middle port then you need a -4 an fitting. you can use you stock injectors but your going to tap them out pretty quick...
dude seriously you need a rrfpr the regular fpr isent going to do much. You are seriously playing with fire by using it... talk to spud he has a begi rrfpr for 100 bucks thats insane thats cheap as hell. I bet if you talk really nice and what not to him he may hold it for you for a little bit till you can get money.
Old Dec 23, 2007 | 01:15 PM
spudsterier's Avatar
spudsterier
i have the fuel pressure on my begi regulator set at 55psi....
if you dont have a rising rate regulator then dont waste the time istalling the turbo....
Old Dec 23, 2007 | 09:39 PM
I_Ride_Neon
Well i have 1400 in it and i need to wait till next week to buy one because i am broke. I will get one. I ran into some problems with it, weather stops me from driving up there, and x-mas is here. So it wont be done for about a week anyways. rrfpr are adjustable? See i was just going to use the fpr to made sure the car will run. When i get the rrfpr should i still use the fpr. If so what order? The thing with the injectors. 1 is different from the other 3. I got them used. the one is a 24 but the other injectors have nothing on them not even a part number. I dont want to use them and run one cylinder rich. With my luck BOOM.
Old Dec 24, 2007 | 12:55 AM
spudsterier
if you have a rrfpr then you dont need a regular fpr.....
most fuel pressure regulators are adjustable for different presures....
you can use the regular regulator to start the car, but you wount be able to build boost
