milling a head...
Old Dec 28, 2007 | 01:25 AM
95to96transplantneon's Avatar
Default milling a head...
how far can you safely mill down a sohc head not crazy mill but safely mill????
does it matter what cam you have???
Old Dec 28, 2007 | 03:54 AM
neonracer1010's Avatar
neonracer1010
Default RE: milling a head...
if you do it, remember to figure out your piston pop up, and then dont take to much off or the piston and valves wont like it
Old Dec 28, 2007 | 09:05 AM
Ghost Neon 2's Avatar
Ghost Neon 2
If you have an sohc neon, you can get dohc piston and bump your compression up to 10.3:1, rather than shaving the head. Head milling is a correcting method used to give a true flat surface to a damamged head. It can be used this way, but if perils strikes you may e stuck without a chair when th music stops. Food for thought.
