97 neon engine problems?????
Old Jan 1, 2008 | 02:30 PM
truckinhil77's Avatar
truckinhil77
Default 97 neon engine problems?????
I got a 1997 dodge neon.. went to start it this morning, it fired up, then shut down... check engine codes are 11, 42, 43... i'm not too familiar with dodge.. what kind of trouble am i in?? any answers would be greatly appreciated....
Old Jan 1, 2008 | 03:01 PM
bone33's Avatar
bone33
Default RE: 97 neon engine problems?????
TROUBLE CODES FOR NEONS 95-99
CODE 11 No distributor referene signal detected during engine cranking....Check circuit between the distributer and the pcm.
CODE 12 Problem with battery connection.Direct battery input to pcm disconnected within the last 50 ignition key-on cycles.
CODE 13** Indicates a problem with map sensor vacuum system.
CODE 14** map sensor voltage to high or to low.
CODE 15** Problem with vehicle speed sensor signal.No vss signal detected during road load conditions.
CODE 17 Engine is cold to long.Engine coolant temp stays below normal operating temp(check thermostat).
CODE 21** Problem with oxygen sensor signal circuit.Sensor voltage to computer not fluctuating.
CODE 22** Coolant sensor voltage to high or to low.Test coolant temp sensor.
CODE 23** Indicates that the air temp sensor input is below the minimum acceptable voltage or sensor input is above the acceptable voltage.
CODE 24** Throttle position sensor voltage to high or low.Test the tps.
CODE 25** Idle air control (IAC) valve circuits.A shorted condition is detected in one or more of the IAC valve circuits.Or a vacuum leak has been detected.
CODE 27 One of the injector control circuit output drivers does not respond properly to the control signal.Check the circuits.
CODE 31** Problem with canister purge solenoid circuit.
CODE 32** An open or shorted condition detected in the EGR solenoid circuit.Possible air/fuel ratio imbalance not detected during diagnosis.
CODE 33 Air conditioning clutch relay circuit.An open or shorted condition in the compressor clutch relay circuit.
CODE 34 Open or shorted condition in the speed control vacuum or vent solenoid circuits.
CODE 35 Open or shorted condition detected in the radiator fan low speed relay circuit.
CODE 37** Open or shorted condition detected in the torque converter part throttle unlock solenoid control circuit.
CODE 41** Problem with charging system.An open or shorted condition detected in the generator Field control circuit.
CODE 42 Fuel pump relay or auto shutdown relay (ASD) control circuit indicates an open or shorted condition.
CODE 43** Multiple cylinder misfire detected.Peak primary circuit current not achieved with the maximum dwell time.
CODE 44 Battery temperature sensor volts malfunction.Problem with the battery temperature voltage circuit in the pcm.
CODE 46** Charging system volts to high>Computer indicates that the battery voltage is not properly regulated.
CODE 47** Charging system voltage to low.Battery voltage sense input below target charging voltage during engine operation and no significant change in voltage detected during active test or alternator output.
CODE 51** Oxygen sensor signal input indicates lean air/fuel ratio condition during operation.
CODE 52** Oxygen sensor signal input indicates rich air/fuel ratio during engine operation.
CODE 53** internal pcm failure detected.
CODE 54** No camshaft position sensor signal from distributer.Problem with the distributer synchronization circuit.
CODE 55 Completion of fault code display on check engine lamp.this is end of message code.
CODE 62 Unsuccessful attempt to update EMR mileage in the controller EEPROM.
CODE 63** Controller failure.EEPROM write denied.Check the PCM
CODE 65** Power steering switch failure.
CODE 72** Catalytic converter efficiency failure.Catalyst efficiency below required level.[/align]
Old Jan 3, 2008 | 09:49 AM
Ghost Neon 2's Avatar
Ghost Neon 2
Did it end with "55"
