My Neon Is running badly
Old Dec 8, 2004 | 05:12 AM
casper's Avatar
casper
Default RE: My Neon Is running badly
Buzzbomb
well i got a 1996 neon today for 1300..
If its a 96 its a 1st gen and the codes Crazy gave you are right, where you got the P codes I don't know. I have a 98 and my codes ring out with the CEL.
Crazy Squee
I'm sorry, I didn't realize he had a 2nd gen. I'm sorry
well if the battery light is on and you are not throwing a code, I would replace the battery, although there should be a code, I think. The gauges probally need to be resoldered, just take the cluster out and either get one from a junk yard or resolder the connections on the back, its not that hard.
Old Dec 9, 2004 | 04:14 AM
Buzzbomb's Avatar
Buzzbomb
ok so i went the dodge dealer and had the guy look at it he pointed out a line said thats my vaccum leak.. well i fixed that and it still dies.. should i just junk it?
Old Dec 9, 2004 | 04:24 AM
Cr@zy Squ33's Avatar
Cr@zy Squ33
Over a vacuum leak? No.
Changet the gasket between the intake manifold and throttle body, replace your idle air control sensor and the throttle position sensor and reset the pcm for 20 minutes to an hour or more by removing the negative battery cable.
And if you are seriously going to gt rid of it I'll take it off your hands.
Old Dec 9, 2004 | 04:36 AM
casper's Avatar
casper
I'm with Crazy on that. Where do you live?? If you live near crazy give it to him, if your near me I take it too, if he does not want it.
Old Dec 13, 2004 | 09:53 PM
Buzzbomb's Avatar
Buzzbomb
ok so i went back to advance auto today.. had them test the battery and alternator and they said both work fine... so what else would keep the battery light on? i like this car i want to fix it :/
Old Dec 14, 2004 | 01:12 AM
Sam Ontario's Avatar
Sam Ontario
ORIGINAL: Crazy Squee
I'm sorry, I didn't realize he had a 2nd gen. I'm sorry.
I thought all 96 year models in North America are OBDII, I might be wrong.
I am new here. Where can I buy a 1996 Neon repair manual, something better than Chilton or Haynes.
Old Dec 14, 2004 | 01:25 AM
Cr@zy Squ33
They are all OBD2.
The only real manual is the FSM (Full Service Manual) an dit pretty much cna only be bought at the dealer. It'll run you about $100 but is well worth it.
You might be able to find one for your car on EBay but I wouldn't bet on it.
Old Dec 18, 2004 | 05:59 AM
Buzzbomb's Avatar
Buzzbomb
well heres an update it was the map sensor it was smashed so i put on a new one and it runs great
Old Dec 18, 2004 | 10:11 PM
casper's Avatar
casper
That will do it every time, lol.
