larger fuel injectors just cause????
Old Jan 8, 2008 | 06:29 PM
jfink's Avatar
jfink
Default larger fuel injectors just cause????
i guy i worked with said i should get venom fuel injectors(larger fuel injectors)to increase horsepower on the top end(even though i'll run rich at low RPM) is it even worth it? sounds like a waste of gas and money if not needed but never heard of that before
Old Jan 8, 2008 | 07:07 PM
95to96transplantneon's Avatar
Default RE: larger fuel injectors just cause????
no not worth it at all you will run rich all across the board... unless you get a adjustable fuel pressure regulator... and without a wide band you wont be able to tune the new injectors... honestly theres no reason to do it...hell you dont need bigger injectors untill you hit 10psi with a turbo or about 180hp NA..
Old Jan 8, 2008 | 07:23 PM
estneon's Avatar
estneon
running to rich can even harm your hp...look at slash and his dohc pcm on his sohc
Old Jan 8, 2008 | 11:12 PM
Slashwannabe's Avatar
Slashwannabe
Yeah it helped for power but it carboned up fast and so you had to clean it out with a rev otherwise it would be a dog and it sucked always tryin to rev when you needed the power now. I took it off and I have more power on the fly cuz I don't have to clean it out with a rev now, plus I get better gasmileage with the stock computer.
I ran really rich with my Walbro 255lph pump for the turboand I took it off and I'm running stock now. I bought a map clamp and I hooked mylaptop computer up to the OBD-2 Port and my air/fuel ratio was like 3/parts fuel to 10 parts air, and its supposed to be like 1/12 ratio which is what it runs good on now. With the map clamp you can adjust your fuel mixture and so I fine tuned it pretty good with my OBD-2 port scanner program on the laptop.
