code 11
Old Jan 12, 2008 | 12:58 PM
lateralus823's Avatar
lateralus823
Default code 11
so i need 2 get my car inspected CEL wont go off says its timing belt skipped a tooth how do i fix it?
Old Jan 12, 2008 | 01:15 PM
jfink's Avatar
jfink
Default RE: code 11
inspect the timing belt for damage or wear, or replace it anyways, and correct the timing cause when it skipped a tooth the timing changed then erase the code from the pcm.
Old Jan 12, 2008 | 10:13 PM
lateralus823
Default RE: code 11
spud? anyone?
Old Jan 13, 2008 | 12:21 AM
neoncrazy101's Avatar
neoncrazy101
Default RE: code 11
just what fink said.
EDIT: cept that code isn't a safety nor an emission code so would it still matter?
Old Jan 13, 2008 | 12:42 AM
noenwarrior's Avatar
noenwarrior
Default RE: code 11
ive had that code before and the timing was just fine. It was a while ago but i think it was just bad plug wires. Ya it was cause it was my msd wires that went bad after having them for a year. But definitly check the timing anyways never hurts to be sure.
Old Jan 13, 2008 | 10:00 AM
lateralus823
Default RE: code 11
ya but i got the p code p1390 which is timing belt skipped a tooth.
lateralus823
Default RE: code 11
i ordered a timin belt kit how much should it ruffly cost to get it dun?
Old Jan 13, 2008 | 10:35 AM
noenwarrior
Default RE: code 11
ya i hade code 11 and a misfire code when i had a plg wire go bad. are you doing the belt yourself? if not a mechanic should beable to do just the belt in a few hours if its a water pump and a belt its a little longer. it takes me roughly 3 hrs to do head gasket and all sometimes less depends on wether condition lol.
Old Jan 13, 2008 | 12:48 PM
lateralus823
Default RE: code 11
waterpump was chaned like a thousand miles ago if that, uncle didnt change the belt said it loojed good.
