changing engines
Old Dec 8, 2004 | 10:45 AM
vase@'s Avatar
vase@
Default changing engines
will a 2000 model engine interchange with a 95 both 2.0
Old Dec 8, 2004 | 11:06 PM
casper's Avatar
casper
Default RE: changing engines
I am pretty sure the basic motor will. The wiring harness and some of the bolt-ons will be different. I don't think Dodge changed the basic motor or trans, or mounts.
Old Dec 8, 2004 | 11:35 PM
morningpride's Avatar
morningpride
Vase,
The engine block and head are essentualy the same. However, as Casper said, some of the wiring,sensors,PCM and other harnesses are not compatable.
The earlier motor mounts are diffrent to!
other than that, I beleave it should work!!
