please help anyone
Old Jan 18, 2008 | 01:06 AM
IzDatAneon's Avatar
IzDatAneon
Default please help anyone
Im trying to finish up my sohc to dohc swap but i need a 95 dohc harness...does anyone have one or know someone who does, or can you tell me if the harness outta 95 dohc eclipse will work for the neon??? please get back to me...
Old Jan 18, 2008 | 01:13 AM
95to96transplantneon's Avatar
Default RE: please help anyone
ORIGINAL: IzDatAneon
try pming ghostneon2 he has last i knew like 4 harnesses however you are aware that you will have to swap every single wire in the car... 95's have one plug that controls the whole car so you will have to tear out the harness from the motor then threw the fire wall to the top of the dash...yada yada yada... I'm not trying to be a *** just making sure you reaslize that...
what year car do you have??? should have asked that...
Old Jan 18, 2008 | 01:21 AM
IzDatAneon's Avatar
IzDatAneon
its a 95
Old Jan 18, 2008 | 01:29 AM
Ok honestly it will be hard to find but when you do...this is what you do so you dont spend 3 days to swap everything out....
if you take the top of the connector off so you expose the wires where they go into the connector you can take a nail and push the wires out the back of the connector and swap all the interior wires from engine harness to engine harness Some have gone as far as to cut the wires and solder on 2 way insulated quick connects to each side of the wire so you can have a removeable engine wiring harness...
I know the first part about the connector is confuessing I can take some pics of mine to show you... however mine is a 96 and it will look different but you will get the point...
Trust me on this I did the compleate swap taillight to headlight... so I could swap in all the 96 wiring so i had two plugs and yes my car is a 95... with all 96 wiring...
