exhaust dump. Heat problems?
Old Jan 18, 2008 | 10:36 AM
I_Ride_Neon's Avatar
I_Ride_Neon
Default exhaust dump. Heat problems?
With my exhaust dumping right off the turbo can i still drive it over an hour on the highway? Midas will do the work for me once i get it back. I am worried because i dont have no guages hooked up to get reading. But the car runs and drives fine? Shold i drive it or no? I could tow it but it would be alot of work. I am getting oil, coolant to the turbo. What do you guys think?
Old Jan 19, 2008 | 03:50 PM
12 volt's Avatar
12 volt
Default RE: exhaust dump. Heat problems?
as long as its not too far awayyou sould be fine depending on what the exhaust is aiming at.
just stop and check if you start to smell smoke
Old Jan 19, 2008 | 03:52 PM
I_Ride_Neon
Okay one more thing. I messed up my intercooler piping bad. Can i use pvc for 1/2 of the piping?
Old Jan 19, 2008 | 03:56 PM
12 volt's Avatar
12 volt
ORIGINAL: I_Ride_Neon
yes
hears some interesting stuff with PVC
http://www.homemadeturbo.com/forum/i...?topic=69917.0
Old Jan 19, 2008 | 05:39 PM
tranyinstaller's Avatar
tranyinstaller
we use pvc at the shop for our pneumatic tools (impact tools) and it holds 100 psi. should be fine for a mere 6psi. just be concious of heat cause it is still plastic
