New dodge neon owner needs help
Old Jan 19, 2008 | 02:41 PM
GunJam's Avatar
GunJam
Default New dodge neon owner needs help
My friend was in the bad situation of needing a cheep car and now is the owner of a 96 neon.
It has a coolant leak from the plastic pipe setup that is behind the water pump. This leak is right where the plastic pipe fits into the water pump housing.
It looks like there are two bolts holding this ridiculous thing to the block of the car and against the mating surface behind the water pump.
Do I just remove those 2 bolts and get a new gasket and some sealant and stick it back in there? What is that thing called?
-Gun
Old Jan 21, 2008 | 02:03 PM
das2123's Avatar
das2123
Default RE: New dodge neon owner needs help
Probably a leaking o-ring.
And yes the water pump is in an inconvenient place.
Old Jan 21, 2008 | 02:53 PM
Ghost Neon 2's Avatar
Ghost Neon 2
Tell me that is not your sister [sm=drlove.gif][sm=drooldude.gif]
Das, as usual, is correct. Plug and play operation. Enjoy
Old Jan 21, 2008 | 08:34 PM
brucewin's Avatar
brucewin
Thatlooks like a nice car. Do you have a pic from the passenger side?
The water pump or back of it gasket ,yeah I had the same proplem.
Old Jan 21, 2008 | 10:05 PM
GunJam's Avatar
GunJam
Yeah It was the O-Ring.
It came apart better than I thought it might. Found an o-Ring that fit pretty good, put some thick grease on it shoved it back in and it works great now....no leaks.
Thanks
-Gun
P.S thats not my sister but that is my mustang! And on I dont have a pic from the passenger side but I do have a video http://youtube.com/watch?v=7TWcwAom6jI
Old Jan 24, 2008 | 10:55 AM
drew67420's Avatar
drew67420
Thats a nice car. You did a great job on the video. I like how it's edited, very nice.
Old Jan 27, 2008 | 12:56 AM
GunJam's Avatar
GunJam
Thanks
I have put a lot of time into ride
-Gun
