bobble strut
Old Jan 20, 2008 | 08:38 PM
97wbody's Avatar
97wbody
Default bobble strut
whats easier cutting and welding the bottom bracket for a atx to mtx swap or fabbing one up?
Old Jan 20, 2008 | 08:42 PM
mopar99's Avatar
mopar99
Default RE: bobble strut
Dont even waste your time on cutting it off. Just fab one up i made mine out of two pieces of 2'x2' angel iron then i bolted them onto the strutandjust welded them on as they layed. Fast and simple.
Old Jan 20, 2008 | 11:32 PM
spudsterier's Avatar
spudsterier
easy solution....
leave it off and get the solid inserts for the front motor mount....you wont even notice its not there
Old Jan 21, 2008 | 01:16 PM
justinsanders's Avatar
justinsanders
how hard is it change out your mm inserts. becaus one of mine is really cracked and i want to get some stiff ones. i know you have to take the motor mounts off and press the new ones in. but is it too complicated?
Old Jan 23, 2008 | 06:36 AM
mopar99's Avatar
mopar99
Its an extremely simple installation. When i did my atx to mtx swap i got the mtx tranny mount used and it was severly ripped so i went to my local auto parts store and got the new insert but used the same steel mount bracket. Then i also had the stiff modern MM inserts to put in as well i just set it in my small bench vice and pressed them in nothing to it.
Old Jan 23, 2008 | 10:53 AM
spudsterier
its very very simple
