Car does not want to run/stay running
Old Jan 30, 2008 | 01:30 PM
12 volt's Avatar
12 volt
Default RE: Car does not want to run/stay running
fuel pressure regulator, no pressure would be the pump
edit might what to check the strainer while your at it
Old Jan 30, 2008 | 01:38 PM
97wbody's Avatar
97wbody
my friend had this problem too a while back it would run for about half hour... it would not start back up right away just crank...if you let it cool down for about another half hour it would start up.. the coil started going out ...
