Battery Cables...hope this one is easy
Old Jan 25, 2008 | 06:30 PM
jdlee's Avatar
jdlee
Junior Member
Default Battery Cables...hope this one is easy
my 99 Dohc Neon dont have the battery tray( dont ask, i bouth it like that) my problem is that the negative battery cable has 2 cablesone goes to the fuse box, but the other one dont know where is supposed to be attach to , it was attach in a bolt that obviosly is notits place cause is hand made if you know what i mean andi sense that this lack of ground is causingramdom troubles in the electrical system in the car...can someone help, i assume this one if fairly easy.
Old Jan 25, 2008 | 07:45 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: Battery Cables...hope this one is easy
You might as well upgrade the grounds to 4 gauge wire and run it to a good ground I'd suggest the strut tower clean the paint and ground it there ...
