fuel pressure
Old Jan 27, 2008 | 06:24 PM
drelix's Avatar
drelix
Default fuel pressure
i just ran a pressure test on my 98 neon 2.0 SOHC and it was @ 50psi. i have been having trouble with misfires. is the feul regulator/filter the cause??and do i have to replace the one in the tank or can i put a inline regulator and filter to bring down the pressure. and would a CAI have anything to do with that high of pressure.
Old Jan 27, 2008 | 07:14 PM
spudsterier's Avatar
spudsterier
Default RE: fuel pressure
50psi isnt really high.....stock pressure should be right around 48psi
Old Jan 27, 2008 | 07:32 PM
Heavy_D508's Avatar
Heavy_D508
i thought neons dont have filters? one dayi went to autozone for my 97SOHC and they said theres no filter for them. they said its a one time thing.
Old Jan 27, 2008 | 07:33 PM
drelix's Avatar
drelix
should the needle on the gauge be steady? or shakey
Old Jan 27, 2008 | 07:47 PM
drelix's Avatar
drelix
the filter is in the tank connected to the pump and combined with the regulator
Old Jan 27, 2008 | 08:14 PM
6sic6's Avatar
6sic6
ORIGINAL: drelix
fuel psi gauge?
mine twitches very slightly at idle but its because Iam running big injectors......
Old Jan 27, 2008 | 08:51 PM
drelix's Avatar
drelix
yea a fuel pressure gauge. and mine goes from 40psi to around 55 psi back and forth real fast.
Old Jan 28, 2008 | 12:43 AM
12 volt's Avatar
12 volt
ORIGINAL: drelix
50psi isnt high at all. you have a fuel filter/regulator (yes both in one piece) mounted on your fuel pump module and a fuel stainer mounted on the end of the fuel pump. just i case your wondering.
yes but not necessary
no.
if that's your car in the sig that would be a warm air intake.
.EDIT. this link gives all the info on the fuel system
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
Old Jan 28, 2008 | 07:12 PM
drelix's Avatar
drelix
no my air filter is shielded from the header and block,it gets good cool air.
Old Jan 28, 2008 | 08:12 PM
spudsterier
it may be shielded from the header and block, but the air in the back of the mtoor still gets heated up pretty good.....you wont have a real cold air intake unless the air filter is in front of the motor
