one problem after another
Old Feb 3, 2008 | 04:26 PM
I_Ride_Neon's Avatar
I_Ride_Neon
Default one problem after another
Now not only is the turbo running 10 pounds, but after i got it all sealed tight i got a crack in my intake manifold. Whats up with that? It was perfect when i put it on. And its the metal one. Well someone answer this please. If i buy a dohc rebuild kit can i use the dohc pistons and gaskets to lower my compression on my sohc? Right? Then i will use a 95 cam also. My timing belt is slapping so i am just going to rebuild it.
Old Feb 3, 2008 | 04:42 PM
Jr. Mechanic's Avatar
Jr. Mechanic
Default RE: one problem after another
That sucks. Yeah, if you use the DOHC pistons it should lower your compression. Btw, did you happen to get up there to get that part?
Old Feb 3, 2008 | 04:51 PM
12 volt's Avatar
12 volt
uuuhh yeah. if you have a SOHC head and you put DOHC pistions the Compression goes up
Old Feb 3, 2008 | 04:53 PM
12 volt's Avatar
12 volt
you should post a pic of the crack. Im curios about where it happend
Old Feb 3, 2008 | 09:10 PM
I_Ride_Neon
Baaa about the part i didnt make it up do to car trouble... Haha. But i am going to call my sisters husband right now i canrt back to you. Okay i got off the phone with him. He is going to grab a box at work tomarrow and ship it off tuesday. Otherwise he is coming up here tuesday he can just bring it with him and i could ship it. Its hard during the week fo rme to get up there because of school. Takes me 40 minutes to get to school.
