Faulty battery??
Old Feb 4, 2008 | 03:42 PM
Dagenhamgeoff's Avatar
Dagenhamgeoff
Default Faulty battery??
Hiya people, not been on here for a while as haven`t had time but now my purple ronnie has died.yet again....battery died after being stood idle for some time, recharged battery only to find the car won`t start..it turns but doesn`t engage, tested voltage of battery 11.21.pretty low eh...whilst cranking it dropped to way below 8v.........so was wondering could the battery have finally given up.....could it be the starter motor.............alternator..........bad ground..... can`t really figure what else it could be...brother in law also has a Neon.lower class ind lol....my battery started his but his battery didn`t start mine....tried jumping but again no joy...forgot to mention its a 98 ATX......tested ASD.fine..all fuse are good to go....plugs coil leads all good to go........the car was running ok before i took battery out to recharge and now nothing..any help guys would be great
Geoff
Old Feb 4, 2008 | 04:38 PM
95to96transplantneon's Avatar
Default RE: Faulty battery??
its the battery... if thats all the charge that its exepting after charging it...
Old Feb 4, 2008 | 06:02 PM
12 volt's Avatar
12 volt
have it tested at you local auto parts store.
