non SRT-4 2.4L
Old Feb 4, 2008 | 04:03 PM
neoncrazy101's Avatar
neoncrazy101
Default non SRT-4 2.4L
i know what is required for an SRT-4 motor swap. but what all is needed for just a 2.4L swap from like a 1st gen. Stratus or something?
Old Feb 4, 2008 | 04:41 PM
95to96transplantneon's Avatar
Default RE: non SRT-4 2.4L
this is a pretty compleat list...
The items with a * are optional but highly recomended...
2.4L Stratus, cirrus, caravan motor 95-99 work the best.
2.4L to 2.0 motor mount Adapter
2.4 motor mount
2.0 DOHC wiring harness
24lb injectors
UDP 2.0
EGR block off kit
DOHC computer
DOHC wiring harness
DOHC intake manifold
DOHC fuel rail
DOHC TPS and Idle air control
DOHC knock sensor
DOHC upper rad hose
DOHC lower rad hose
DOHC thermostat housing
DOHC header
Thermostat
clutch *
DOHC Hood
2.0 cams *
pt alt brackets
assorted fluids and such
intake gasket
exuast gasket
PT water inlet pipe *
DOHC heater hard lines *
