My neon doesnt turn on :(
Old Feb 6, 2008 | 11:30 AM
jimador69's Avatar
jimador69
Default My neon doesnt turn on :(
my car won't turn on? Everything works. i have power, my starter turns over but the car just won't turn on. I just gave it an entire tune up including oil, oil filter, spark plug wires, spark plugs, fuel injector cleaner. i have a 1997 sohc 2.0. I have tried putting starter fluid also and it won't budge. I live in flagstaff where every night it freezes over could this be the problem? and if it is what can i do to fix the problem or at least turn the car on? Otherwise It just won't turn on with everything working on it. i checked the fuses and relays.
Old Feb 6, 2008 | 06:05 PM
bone33's Avatar
bone33
Default RE: My neon doesnt turn on :(
put gas in it.
check fuel pump.
Old Feb 11, 2008 | 04:08 PM
12 volt's Avatar
12 volt
but a haynes manual and dothe no start test, porbably ASD relay
Old Feb 12, 2008 | 06:58 AM
Ghost Neon 2's Avatar
Ghost Neon 2
Having the same issue here. Just went through the joy of swapping in a newer fuel pump from the yard, and the pump still is not priming.
Old Feb 12, 2008 | 03:42 PM
I_Ride_Neon's Avatar
I_Ride_Neon
Heads up. Junk yard fuel pumps are usually bad. I went through 3 in one week. I ended up just buying a new one. No problems ever again. Once the pump goes dry on the shelf the seals and everything else goes bad.
Old Feb 14, 2008 | 09:50 AM
Ghost Neon 2
The yard here leaves them in the tank. Got mine from an 02. This was done in a pinch, but newer pump are ideal. Also worked on my 87 k-wagon.
