SOHC/DOHC COMPATABILITY
Old Dec 16, 2004 | 07:18 PM
malaki66's Avatar
malaki66
Default SOHC/DOHC COMPATABILITY
I DRIVE A 97 EXPRESSO AND JUST AQUIRED A 95 SPORT WITH A REBUILT BOTTOM END . WHAT PARTS BESIDES THE THROTTLE BODY ARE COMPATIBLE BETWEEN THE TWO.
Old Dec 16, 2004 | 08:59 PM
casper's Avatar
casper
Default RE: SOHC/DOHC COMPATABILITY
Everything is the same I believe other than from the head up.
Old Dec 20, 2004 | 06:29 PM
Cr@zy Squ33's Avatar
Cr@zy Squ33
Blocks are identical, heads are different. You can however swap the heads over.
Old Dec 21, 2004 | 03:10 AM
RT_Driver's Avatar
RT_Driver
The pistons are also different. The DOHC have value reliefes, where the SOHC don't. SO... DOHC has stock 9.2:1 comp. and SOHC has 9.8:1.
Old Dec 22, 2004 | 05:03 PM
LowSlowNeon's Avatar
LowSlowNeon
Doesn't DOHC have higher compression? Meaning you got those ratios backward?
Old Dec 23, 2004 | 04:09 AM
RT_Driver's Avatar
RT_Driver
No, the DOHC has lower comp. from the factory.
