98 NEON Leaks/Sprays Oil out HELP
Old Feb 18, 2008 | 07:53 PM
ymcaman's Avatar
ymcaman
Default 98 NEON Leaks/Sprays Oil out HELP
I recently noticed my neon had the pressure light on. Check the oil no oil. Car has always had a little click noise for the last 20,000 miles. have always checked the oild and never any problems other then a slow pan gasket leak. So I assumed something had went hay wire.... checked to make sure no leakes/cracks from the pan or the filter.... none. So then put a quart of oil in. Started the car .... within about 10 seconds oil came down at a very fast rate . It was dripping from somewhere above the Oil Filter. Again the Oil filter is good. Im guessing some line or something is unhooked since it basically sprays out. Again it is dripping out very fastly from somewhere above the oil filter... the oil comes down the side of the engine and is drips down at a rapid rate approximately 2 inches towards the passenger wheel from the oil filter. HELP ME!!!!!!!!
Old Feb 18, 2008 | 07:55 PM
6sic6's Avatar
6sic6
Default RE: 98 NEON Leaks/Sprays Oil out HELP
oil pump is on that side, so is the crank sensor??????
Old Feb 18, 2008 | 09:56 PM
ymcaman's Avatar
ymcaman
So one of those two would make oil leak on the outside of the engine?????
