turbo vacume lines
Old Feb 19, 2008 | 02:14 PM
mmench's Avatar
mmench
Default turbo vacume lines
ok what line do i hook up were on the srt4 turbo... am am running a agp WGA and a forge BOV. andbody have any pix or diagrams that i can use to show me. wich lines to cap and wich need to be hooked together
Old Feb 19, 2008 | 11:54 PM
spudsterier's Avatar
spudsterier
Default RE: turbo vacume lines
which ones do you need to know about???
Old Feb 20, 2008 | 06:25 AM
mmench's Avatar
mmench
the lines that come from the turbo... i know the small nipple on the boost side (on the top right side of housing) is recomended by AGP to go to the WGA. im not sure wat to do with the one on the outlet from the turbo on the boost side( were boost come out) or wich line i should use to hook up to my BOV
Old Feb 20, 2008 | 09:56 AM
spudsterier
i blocked off both the fittings on the turbo housing and put 2 T fittings in my brake booster line...1 for the WGA and one for the BOV
Old Feb 20, 2008 | 10:13 AM
mmench's Avatar
mmench
kool thanks spud.. i am using the tops one for the BOV and bottom one for the WGA i think... makes it less hassle of splicing in fittings. but i may switch the order i have them hooked up because of nipple sizes on the housing and acessories
