evap canister
Old Feb 26, 2008 | 12:42 AM
dirt_trac_racer_80jr's Avatar
Default evap canister
so can i get rid of it or not ...im not sure exactly wat it does ....doesnt it just filter exhaust gas or sumpin like that...??
Old Feb 26, 2008 | 01:02 AM
95to96transplantneon's Avatar
Default RE: evap canister
it filters the "gas fumes" from the gas tank and puts them into your intake... its a envorment thing... raw unspent gas has alot of hydrocarbons witch is bad for the o-zone. the only reason for the coal canister is to make sure the fumes are "dry"...
if you do remove it you have to remove the rubber o-ring on your gas cap, and plug the hole coming from your gas tank...
but we all need to be green so leave it alone... unless you have to remove it...
Old Feb 27, 2008 | 01:23 AM
its a race car ..it doesnt have a gas tank ..it has a 5 gallon fuel cell..the only reason i wanna take it off is because its in a bad location and will most likely get smashed...but i ges ill jsut leave it on untill it does ...thanks
Old Feb 27, 2008 | 10:38 AM
spudsterier's Avatar
spudsterier
i took mine out a while back...now my coolant over flow tank sits there
its nice not having it since you can also get rid of other junk under the hood
