Parking Brake
Old Feb 28, 2008 | 11:54 AM
DuraMassillon's Avatar
DuraMassillon
Default Parking Brake
My parking brake doesn't engage after replacing rear drums / shoes / hardware / cylinders. Everything back there is hooked up fine, so I'm about 99% sure that my issue is where the cable connects to the lever inside the vehicle.
Anyone have pictures, diagrams or general help for this? I've been told that it's a huge ordeal, removing seats and the like. Also I did search the site to no avail.
Thanks in advance for any help!
Old Feb 28, 2008 | 04:34 PM
95to96transplantneon's Avatar
Default RE: Parking Brake
you dont have to remove the seats just remove the center console and thechilton's manual will guide you how to do the rest...
Old Feb 28, 2008 | 04:51 PM
Jr. Mechanic's Avatar
Jr. Mechanic
Sounds like you are getting ahead of yourself there... There is an adjuster in the drum for the E brake, simply remove the rubber grommet on the rear of the drum, stick a slot head screwdriver in the hole and turn the mechanism inside. Cant really tell you off the top of my head which way, but that is your problem.
