should i buy this header
Old Mar 1, 2008 | 05:16 PM
justinsanders's Avatar
justinsanders
Default RE: should i buy this header
i already bought it,where can u get a 1/4 watt 1 miliamp resistor
Old Mar 1, 2008 | 05:26 PM
unclemike's Avatar
unclemike
You mean a 1/4 watt one megaohm resistor? Try Radio Shack.
Just a thought, when you are buying Pacific rim products you have to consider everthing in the manufacturing chain. Not just the finished product. Thing like alloy purity, welding rod or wire composition, and etc. It can be a pretty looking item but it will be worthless if it's made from junk steel.
After being burned several times Mattel Toys announced it would be doing its own quality and safety testing on toys made overseas. This should give you pause.
Old Mar 1, 2008 | 05:31 PM
justinsanders
ok once i find one i splice the black wire on the downstream o2 sensor and install the 1/4 watt one megaohm resistor on that wire?
Old Mar 1, 2008 | 05:37 PM
unclemike's Avatar
unclemike
The instruction that come with the header should tell you
Old Mar 1, 2008 | 05:48 PM
justinsanders
o really? ok thanks
Old Mar 1, 2008 | 05:53 PM
justinsanders
how many percent tolerance should it be
Old Mar 1, 2008 | 06:11 PM
unclemike's Avatar
unclemike
If not, just post the question here. As a matter of fact you could do it now. One of the member who did this will be glad to tell you how.
Old Mar 1, 2008 | 08:29 PM
justinsanders
will these resistors work. there 1/4 watt1 mega ohm resistors but there 5% tolerance i didnt know if that was wat i needed or not thanks
[IMG]local://upfiles/63489/AADEE7A9FB1745509DB6C3FE27692EB0.jpg[/IMG]
Old Mar 1, 2008 | 08:41 PM
unclemike's Avatar
unclemike
They should work just fine, but is this for the oxygen sensor or the MAP sensor?
Old Mar 1, 2008 | 11:25 PM
justinsanders
oxygen sensor. i was told you install this resistor on the black wire to trick the computer that theres a cat there and everythings fine, any one know?
