2.4l N/A swap questions
I wanna do a 2.4l swap(naturally aspirated)from a 01 Pt Cruiser. So my questions and concerns are as follows. I have a great deal of mechanical knowledge but not a whole lot on the wiring harness. What wiring harness mods should i expect? Can I use a 98-99 2.0 DOHC pcm from a mtx neon? Will I be able to use the harness I have or buy a new one, etc...? If I have to buy a new one which harness would be ideal for the swap.The neon is a '99 2-door 2.0 SOHC with a atx. I already know what to expect to convert it to a mtx. I think the TH350 will bolt up but I would like to be sure before I invest in the pt motor. All input would be greatly appreciated.
trans will bolt right up and work just fine... athough many people are going to tell you to swap to mtx... I say what ever you want to do is your buisness... but yes it will swap... there isent really that much wiring you will have to do....
check your pm's I will sorta guide you threw this...
In all honesty I wanna make it reliable and still run mid 13's. Would this be the best baseline combo(2.4l w/ mtx 3.94 ratio)? Or should I try and find a 2.0 Magnum. What's the difference between the 2.0 mag and the regular 2.0 (is it just compression)?
