Car Died Again! Maybe fuel pump
Old Mar 7, 2008 | 09:03 PM
djseth's Avatar
djseth
Default Car Died Again! Maybe fuel pump
I was driving at 60mph the other day, and the car just died. There was absolutly no stutter of the engine or indication that it was having a problem. It just stopped driving. I have full electrical operation of all componets (i.e. lights, stereo, gages). The engine turns over fine, and it just won't start. Tomorrow, I will check that there is spark, and that I am getting fuel to the injectors. Is there anything else that I might be on the obvious look out for? I think it might be the fuel pump or the ignition module. I visually inspected the fuel pump fuse (it looked ok), but I will test the connection with an ohm meter. Could the relay be bad? Any input helps.
Thanks
Old Mar 7, 2008 | 09:10 PM
djseth's Avatar
djseth
Default RE: Car Died Again! Maybe fuel pump
I forgot to ask. Even though the dash didn't display an error message, is it possible that the car still threw a code that I can read with an OBD reader?
Old Mar 7, 2008 | 09:26 PM
vipersforsale's Avatar
vipersforsale
my 99 buick lesabre did the same thing... it was the Crankshaft Position Sensor. It didnt ever throw a code either, maybe the neon acts the same way...
Old Mar 8, 2008 | 10:56 PM
HarleyRider68's Avatar
HarleyRider68
Yep, crank sensor. Could possibly be the cam sensor, but I think te CEL would come on. Check the fuel pressure at therail.
Old Mar 11, 2008 | 11:53 AM
djseth's Avatar
djseth
Ok, my fuel pump is working and I am getting fuel to the rail. I'm not getting spark. I can check the signal to the crankshaft pos. sensor buy I can't get my probes into the sensor to test the return signal to see if it is not sending one (it is poorly placed). Does anyone know a good way to back track the wires to read the signal out? Also, shouldn't the cam shaft pos sensor compensate for the crank if it fails? I will try testing the ignition module soon too to eliminate that. Any other sensors that I should check?
