Is there any other transmission?
Old Mar 10, 2008 | 10:13 PM
krusher101's Avatar
krusher101
Default Is there any other transmission?
Hey guys. Is there any other transmission that will bolt into a neon? Like a daytona or avenger?
Old Mar 11, 2008 | 12:11 AM
Ghost Neon 2's Avatar
Ghost Neon 2
Default RE: Is there any other transmission?
The daytona trans will require some fabrication, as the starter on the 2.2L/2.5L is in the rear.
The 5sp avenger/sebring/ non-turbo eclipse/talon transmission is the same as the neon r/t. It does require that you swap the bell housing, as all the aforementioned vehicles use a hydraulic shifting mechanism on the 2G neon. Swap that and you have an r/t trans. Those are your options, save taking one from another neon.
