harness
Old Mar 20, 2008 | 01:03 PM
I_Ride_Neon's Avatar
I_Ride_Neon
Default harness
Will a atx hanress from a 96 sohc work on a 96 sohc mtx? What modification is required?
Old Mar 20, 2008 | 01:46 PM
droppedneon's Avatar
droppedneon
Default RE: harness
it will work. thats what i did when my atx died. you have to just ground out 2 wires thats 2 the trans i forgot the name of the splug. its the plug that has 3 wires. ill let you kjnow what color the wires are later tonight. i have to swap my engine harness on my car.
Old Mar 20, 2008 | 10:08 PM
spudsterier's Avatar
spudsterier
Default RE: harness
though if you get a manual pcm then you shouldnt have to ground the plugs because it wont rear those sensors
the motor hanress will work
Old Mar 20, 2008 | 10:09 PM
I_Ride_Neon
Default RE: harness
Thanks. I assume I just remove the tranny plugs from the harness that were used on the auto tranny?
Old Mar 20, 2008 | 11:20 PM
95to96transplantneon's Avatar
Default RE: harness
you can if you would like, however it would just be easyer to snip the plug off and tape it down to the rest of the harness with electrical tape...
