PCV VALVE REPLACEMENT
Old Mar 23, 2008 | 07:26 PM
rockenuptown's Avatar
rockenuptown
Default PCV VALVE REPLACEMENT
How do I replace a pcv valve on a 2.0 sohc neon 98 model. If you can give me a picture of where it is thanks.
Old Mar 23, 2008 | 10:42 PM
95to96transplantneon's Avatar
Default RE: PCV VALVE REPLACEMENT
pretty simple... just note the direction the pvc valve is in when you take it off and just replace the same way... heres a pic of its location... may differ slightly from your vehical... but will be in very close procimity of where i have circled...
Old Mar 24, 2008 | 02:25 PM
mcss8541's Avatar
mcss8541
Thanks for the help. I was just getting ready to post that question. Also that hose that goes up to the top of the valve cover rotted, can I use a standard piece of hose or does it have to be that hard preformed type?
Old Mar 24, 2008 | 08:42 PM
I found a 90* angle pice that the hose would fit into and then onto the vc... if you get a hose that is as big as the vc then it will not go on the pvc valve... if you need a close up let me know...
Old Mar 27, 2008 | 02:01 PM
mcss8541's Avatar
mcss8541
yes please.
