99dohc engine CHEAP
Old Mar 26, 2008 | 06:45 PM
ol skool's Avatar
ol skool
Default 99dohc engine CHEAP
99 dohc complete including wire harness and computer. bought car did not run turns over 131,000 on odometer had a 97sohc put in car had low mileage . i want a $100.00 for dohc i live by rochelle il.must be picked up!more info 815-739-2887 bob
Old Mar 26, 2008 | 08:06 PM
I_Ride_Neon's Avatar
I_Ride_Neon
Default RE: 99dohc engine CHEAP
Whats wrong with it? Locked up? If the engine turns and the head is in good shape I will give you $200 If you drive 45 minutes.
Old Mar 26, 2008 | 11:35 PM
spudsterier's Avatar
spudsterier
damn...if i had a pickup then i would deliver it for ya....rochelle isnt very far from here at all
Old Mar 27, 2008 | 01:03 PM
ol skool's Avatar
ol skool
bought the car off ebay not running i had a good sohc so i pulled it without checking out too much tried to start had spark and fuel. engine turns over never took a compression reading new waterpump and timing belt on it from previous owner.if you want to come and get it i can load in your p/up with engine hoist
