Altenator or Battery NEED HELP ASAP
Old Mar 30, 2008 | 02:29 PM
boxerjl2's Avatar
boxerjl2
Default Altenator or Battery NEED HELP ASAP
how do i know if its the altenator or the battery
i can jump start the car with my truck then i unhook it and the neon stays running.. then i shut it off and i cant get it to start back up.. so is it the aletenator or battery
Old Mar 30, 2008 | 02:45 PM
fsu182's Avatar
fsu182
Default RE: Altenator or Battery NEED HELP ASAP
have the alt tested at autozone - theyll do it for free.
happened to me - was my battery. a post actually went bad.
Old Mar 30, 2008 | 03:30 PM
spudsterier's Avatar
spudsterier
while the car is running, disconnect the positive battery terminal...
if the car dies, then your alternator is bad
Old Mar 30, 2008 | 04:45 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
Sounds like its the battery to me.
Old Mar 30, 2008 | 05:04 PM
95to96transplantneon's Avatar
X3 for the battery...
Old Mar 31, 2008 | 02:31 AM
boxerjl2's Avatar
boxerjl2
ok sweet Spud thanks alot!!
i finally had the time to check it out and it was the battery so i filled the little holes with some water and then had to go work.. but it started like it should when i got there so thanks alot.. i wasnt sure if it was the battery cuz i chnage it out (with another old one) but guess it just needed some water which i dont understand how water keeps it charged
Old Mar 31, 2008 | 08:17 AM
spudsterier
when the battery get a charge to it, the charge bounces around between all the plates inside the battery....once the water gets a charge, it becomes battery acid....
or sumthing like that
