DOHC Turbo upgrade question
Old Apr 4, 2008 | 10:56 PM
cuwa's Avatar
cuwa
Default DOHC Turbo upgrade question
I have a 98' DOHC neon and im putting a turbo kit in it the only thing i cant find out how to do is wire in a APEXI AFC NEO. Any advice would help a lot.
Old Apr 4, 2008 | 11:12 PM
95to96transplantneon's Avatar
Default RE: DOHC Turbo upgrade question
ok first off welcome to the DF
second off what kind of turbo are you running that requires you to run a neo???
What does your turbo kit include??? ie fuel system, type of turbo type of manifold...
Where did you buy it???
not trying to figure thigns out need to know to give you an answer...
Old Apr 5, 2008 | 09:11 AM
cuwa's Avatar
cuwa
The turbo is a T3 Not real sure of what brand... The turbo said DSM-EVOIII
I have the manifold w/ external waistegate. Greddy BOV.
oil return lines, 38 mm external waistegate. Front mount intercooler. Nology hotwires and plugs. And the Neo Fuel system im getting is a Venom fuel rail, injectors, and pump. I bought it all from a friend who was getting ready to put in his car but totaled it first. This is the first time im boosting a car that was N/A. The mecanic i was going to use told me i needed a fuel management system, But didnt need stand alone.
Old Apr 5, 2008 | 01:40 PM
JackMehoffer69's Avatar
JackMehoffer69
for fuel managment i'm using a synapse missinglink ML006C, obx 10-1 fuelmanagmentunit, walbro 155 inline mounted pump and thats about what i can remember for now. ngk bkr7e spark plugsi'm using as well.
