Bigger injectors
Old Apr 6, 2008 | 12:23 AM
I_Ride_Neon's Avatar
I_Ride_Neon
Default Bigger injectors
I got those accel 24lbs. My question is what do i do to tune for them? I am just running stocks with my walboro, aeromotive rrfpr froms jegs. Do i just adjust my idle fuel pressure?
Old Apr 6, 2008 | 02:24 AM
95to96transplantneon's Avatar
Default RE: Bigger injectors
if you have a good A/F ratio you just need to dial down the pressure a bit till you get a good A/F again at idle... the injectors will dump more fuel...
Old Apr 6, 2008 | 06:46 PM
I_Ride_Neon
Well I dont have air/ratio or wideband. Should i just do the math? stock neons injectors are 16's right?
Old Apr 6, 2008 | 08:46 PM
19lb i really wouldent be able to tell you how far you need to back it down othere then get a a/f meter even one of the narrow band and just get it somewhat happy
