Battery temp sensor volts out of range
Old Apr 9, 2008 | 10:31 PM
hitandrun83's Avatar
hitandrun83
Default Battery temp sensor volts out of range
what does this mean?
Old Apr 9, 2008 | 10:34 PM
das2123's Avatar
das2123
Default RE: Battery temp sensor volts out of range
Means its probably disconnected. Or maybe your alternator is going bad.
Old Apr 9, 2008 | 10:46 PM
95to96transplantneon's Avatar
that temp sensor is really fragile too.. may be cracked
Old Apr 9, 2008 | 10:55 PM
das2123's Avatar
das2123
Very true.
Old Apr 9, 2008 | 11:10 PM
hitandrun83
well went spent 4 or 5 hrs tonight out in the cold looking for loose wires, and decided to check the engine codes, and your right, it was disconnected! LOLoh god now we can all rest now!
