Stuck with motor mount now!!![progess, stuck on one bolt now]
Old Apr 10, 2008 | 07:14 PM
Dumonic's Avatar
Dumonic
Default RE: Broken Crank sensor
I'mway past that point my friend, the sensor is broken of inside the engine, I've tried drilling a screw into it but not working. I don't want to have to take the oil pan off because the front motor mount is in the way and I can't get the bolts off.
Old Apr 10, 2008 | 07:55 PM
Jr. Mechanic's Avatar
Jr. Mechanic
Sorry to say, but you pretty much screwed yourself over then there, lol. Even if you take the pan off, I dont think the sensor is accessible, but I may be wrong.
Old Apr 10, 2008 | 08:20 PM
Ghost Neon 2's Avatar
Ghost Neon 2
ORIGINAL: Jr. Mechanic
Did all at is mentioned above, and i solved it by removing the pan, and pushing out the remaining portion of the crank sensor. It can be done.
*EDIT* After replacing the CPS, I found there was damaged wiring connect to my working CPS. That is where my code came from. Heads up there.
Old Apr 10, 2008 | 08:33 PM
Dumonic's Avatar
Dumonic
ok, it's do able, but how do I get the dam motor mount off. There's two bolts on the top of the bracket I can't access. The other two that are visable won't budge. It's only one bolt on the oil pan that the bracket is hiding. Is there a way to get that bolt out without taking this bracket off. Cause I can't afford to tow the car to the garage and have them do it. It's almost like I need a special impact to get in there. I tried using an electric impact but can't even get it in position...no room.
Old Apr 11, 2008 | 08:31 AM
das2123's Avatar
das2123
You can get to all of the bolts for the motor mount. It isn't very difficult to get off.
Old Apr 11, 2008 | 10:45 PM
Dumonic's Avatar
Dumonic
what do you use, because i can't get them loose with a ratchet. And the impact doesn't fit, unless there's a special angled socket. I have pictures, but don't know how to upload them/
Old Apr 11, 2008 | 10:58 PM
Dumonic's Avatar
Dumonic
Default Stuck with motor mount now!!!
Picture #1 more to follow, have to add one at a time because of the size
[IMG]local://upfiles/87865/D1AFB71A87804A89829C08299A92DBDC.jpg[/IMG]
Old Apr 11, 2008 | 11:00 PM
Dumonic's Avatar
Dumonic
Default RE: Stuck with motor mount now!!!
Picture 2
[IMG]local://upfiles/87865/C135A971215749578CDE2347F13F3769.jpg[/IMG]
Old Apr 11, 2008 | 11:01 PM
Dumonic's Avatar
Dumonic
Picture 3
[IMG]local://upfiles/87865/102553C3C2E5498FB632E6C7EB8E782D.jpg[/IMG]
Old Apr 11, 2008 | 11:02 PM
Dumonic's Avatar
Dumonic
Picture 4
[IMG]local://upfiles/87865/192918D4D6FD4FA79DD57DFFD9C5C55B.jpg[/IMG]
