How do I pull off cam gear?
Old Apr 11, 2008 | 07:24 PM
djseth's Avatar
djseth
Default How do I pull off cam gear?
I have a 96 neon SOHC that I am fixing up and I can't seem to get the cam gear off. Any help? I have tried to lock it into place with a flat bar and loosen it with a breaker bar and socket. Do I need a special tool?
Old Apr 11, 2008 | 07:35 PM
bone33's Avatar
bone33
Default RE: How do I pull off cam gear?
you have to put 2 M-80's behind it and run.
Old Apr 11, 2008 | 08:42 PM
I_Ride_Neon's Avatar
I_Ride_Neon
Are you talking about the bolt? Use an impact.
Old Apr 11, 2008 | 08:45 PM
djseth's Avatar
djseth
Yes, the bolt is what is stuck. I don't have an impact wrench though. If I just need to put more torque on the bolt, I will. I just didn't want to break anything.
Old Apr 11, 2008 | 10:14 PM
neonracer1010's Avatar
neonracer1010
u need an impact, its makes it so the cam doesnt rotate.
Old Apr 12, 2008 | 02:37 AM
j_son600's Avatar
j_son600
Possibly use a oil filter wrench or something similar to hold the cam gear may work, but impact is defiantly the way to go.
