WTB: stock DOHC pistons
Old Apr 12, 2008 | 06:03 PM
jfink's Avatar
jfink
Default WTB: stock DOHC pistons
well went to the junk yard to get DOHC pistons and put into my sohc and after taking the head off the pistons had rust.....so i justbought the head.(project down the road). but for now i want to put dohc pistons into my sohc for a few more horses. so i am looking to spend around $50 anybody with a good set pm me. thanks.
Old Apr 12, 2008 | 08:21 PM
12 volt's Avatar
12 volt
Default RE: WTB: stock DOHC pistons
get the ones with rust and have them cleaned up. as long as the ring lands and the skirts are okay you sould be fine.
http://www.embeeperformance.com/
these guys do anti friction and thermal coating.
Old Apr 12, 2008 | 10:06 PM
jfink's Avatar
jfink
???? are you sure they will be fine?? would like other opinions, not that i doubt you, its just if this messes up my engine i cant afford to fix it. figure it would mess up compression, create ruff edges, etc. oh and cant afford to take them somewere to have them cleaned up. would have to do it myself. the less i spend on this the better.
Old Apr 13, 2008 | 09:53 PM
I_Ride_Neon's Avatar
I_Ride_Neon
I will have 4 out of an engine that still runs but has a bad bearing.
Old Apr 14, 2008 | 08:53 AM
das2123's Avatar
das2123
It's just like the rust on brake rotors. Clean them off and they are fine.
Old Apr 14, 2008 | 09:40 AM
Ghost Neon 2's Avatar
Ghost Neon 2
ORIGINAL: das2123
Perfectly put. If you wanna be cautious, have they magnafluxed for cracks at a machine shop.
Old Apr 14, 2008 | 10:52 AM
jfink's Avatar
jfink
alright then its settled. back to the junk yard i go. thanks for the help. I_ride_neon i'll get back to you just in case i still need one or more thanks.
