help plz !!!!!!!!
Old Apr 13, 2008 | 09:05 PM
blue_knight8's Avatar
blue_knight8
Default help plz !!!!!!!!
i have a 95 neon sohc 5 speed that im doing a swapto a dohc i need a pcm but cant find one i know i need a pcm out of a 95 or 96 neon but when i go to autozone they ask for the pcm code ? i only have the code for the sohc and someone plz tell me what the code is for a 95 or 96 neon pcm 5 speed dohc or some thing that will work for me ?
Old Apr 14, 2008 | 12:00 AM
spudsterier's Avatar
spudsterier
Default RE: help plz !!!!!!!!
the cheaper way would be to just order a mopar performance pcm....its actually about $100 cheaper then a new factory pcm...
unless your planning on throwing a turbo on the car as well...then you cant use the mopar
Old Apr 14, 2008 | 01:22 PM
das2123's Avatar
das2123
You need a PCM from a 95 only....and go with the Mopar one while you are at it. Don't buy it from Autzone....
http://www.modernperformance.com/pro...oducts_id=1429
