WHERE DOES THE TACH WIRE GO????????
Old Apr 15, 2008 | 02:14 PM
mcss8541's Avatar
mcss8541
Default WHERE DOES THE TACH WIRE GO????????
My 97 SOHC MTX Neon does not come with a tach so i want to install one. since this type has a different type of coil set up than i'm used to where would i hook up the wire. also this car does not have a "LOW FUEL" light that comes on located in the instrument cluster. is this common for my yr? and lastly i'm in need of fron struts and rear shocks. i will be upgrading from the golf cart stock tires and wheels (14") to some 17"s, any suggestions???????????
Old Apr 15, 2008 | 07:02 PM
95to96transplantneon's Avatar
Default RE: WHERE DOES THE TACH WIRE GO????????
tach wire is behind the cluster...
1. take out the cluster
2. you will see 2 wiring plugs... lift up on the right one...
3. tach wire is gray with blue stripe
Old Apr 15, 2008 | 10:18 PM
das2123's Avatar
das2123
ORIGINAL: mcss8541
Neons don't have rear shocks....they are struts all the way around .
KYB GR-2 struts are a great replacement. I still say 15's are the best
Old Apr 16, 2008 | 08:37 AM
mcss8541's Avatar
mcss8541
These STRUTS can be purchased through Jegs or Summuit racing?????? Why 15's? Just asking because all my friends with Neons are running 17's.
Old Apr 16, 2008 | 08:38 AM
mcss8541's Avatar
mcss8541
Thanks 95!
Old Apr 16, 2008 | 09:25 AM
das2123's Avatar
das2123
ORIGINAL: mcss8541
Yes, you can even get them through ebay for a little cheaper.
ORIGINAL: mcss8541
Because 15's don't hurt acceleration. 17's slow the neon down a bit, EVEN if they are lightweight.
Old Apr 16, 2008 | 10:22 AM
mcss8541's Avatar
mcss8541
Thanks again but I just want the look I'm not into racing Neons although I have seen some fast ones.
