97 neon wont start, no power at all
I mean it would give you an idea of where power is getting to... I would test where the starter connects, first using the battery for ground then the block for ground.. then the pdc box... then test teh coil pack middle wire with the key in the on postion...
I would also go threw every fuse and check them all... ie take multi-meter on the conduence checker and make sure there good... not just look good...
