Got the new atx tb on!!!!!!!!!
Old Apr 19, 2008 | 02:05 AM
95to96transplantneon's Avatar
Default RE: Got the new atx tb on!!!!!!!!!
Boxer had one and when i took it off when doing the 2.4 swap it was upside down and was blocking flow... they designed them upside down... there not really worth it what so ever...
Old Apr 19, 2008 | 02:29 AM
Neon_Freak's Avatar
Neon_Freak
ight bro...can u get on aim so i can talk to ya??? get back at me ight or add me at BURN_THE_PREIST@hotmail.com k later
Old Apr 19, 2008 | 04:18 PM
Neon_Freak's Avatar
Neon_Freak
i dont know if this is common with this swap but when im driveing my car is sputters like throttle is closed as long as im given it gas it wont do it do i need to switch the black bracket off the atx neon to my atx tb???? and is my throttle cable suposed to b loose also? seems loose to me
Old Apr 19, 2008 | 08:59 PM
das2123's Avatar
das2123
ORIGINAL: Neon_Freak
but in my manifold its all black with carbon..i cleaned the my new tb bcuz it had a lot of carbon on the underside of it..
Thank your EGR valve for the carbon buildup
is there anything i could get from autozone under $100 that would give me more HP?
NOS stickers [sm=bling.gif]
But seriously, NO!
Old Apr 19, 2008 | 11:25 PM
oh come on it will add at least 50 hp
lol
Old Apr 20, 2008 | 01:23 AM
Neon_Freak's Avatar
Neon_Freak
i went to autozone and ending up buys some new ngk plugs.. runs alot better now!!!!
Old Apr 20, 2008 | 06:28 PM
Neon_Freak's Avatar
Neon_Freak
jw but is my car supposed to b idleing higher than it did with the mtx tb on it??? its runs like around 1500 just geussing tho dont have a tach.
Old Apr 20, 2008 | 07:56 PM
Ghost Neon 2's Avatar
Ghost Neon 2
For under $100, new filled/solid engine mounts or a Magan underdrive pulley off ebay. Do you have a dohc or sohc?
Old Apr 20, 2008 | 09:13 PM
Neon_Freak's Avatar
Neon_Freak
i have a sohc. i didnt get that 100 just had 20 so i got new ngk plugs and some fuel treatment.
Old Apr 21, 2008 | 12:24 AM
fsu182's Avatar
fsu182
how did the gasket look when you took off your throttle body? 1500 is too high. probably a small vacuum leak.
