Short Shift Install
Old Apr 23, 2008 | 11:45 AM
Tweaked_Neon's Avatar
Tweaked_Neon
Default Short Shift Install
hi, i just got a new short shift for my 95' and not quite sure how to install it, im sure i can figure it out as i go, but are there any tips or guides to help me out?
Old Apr 23, 2008 | 02:04 PM
12 volt's Avatar
12 volt
Default RE: Short Shift Install
1 remove center consol
2 fold the shifter cover up exposing the bottom of the shifter
3 push out on the two plastic tabs that hold the **** on and pull the **** off
4 disconnect the sifter cables (good place for some booger bushings)
5 remove the C clip that hold the side arm and the sping to the shifter and remove the arm.
6 unscrew the three nuts from the top of the shifter and pull the handle up.
7 push the shifter out of the bottom of the housing.
installation opposite of removal
Old Apr 24, 2008 | 03:54 PM
Tweaked_Neon
great, i got it in yesterday
