code check with key
Old Apr 24, 2008 | 09:18 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
Default code check with key
i got a stupid question. instead of a CEL i have a service engine soon light. probably the same thing but when i try to do the key thing to check codes NOTHING happens. WTF is going on?
Old Apr 24, 2008 | 09:24 PM
thedark69's Avatar
thedark69
Default RE: code check with key
Explain the way you do it and ill tell u whats wrong i do that thing with mine and it works well
Old Apr 24, 2008 | 10:17 PM
DOHCgarrett t3
on off on off on... is there another way??
Old Apr 24, 2008 | 10:56 PM
thedark69's Avatar
thedark69
normally its On-Acc-On-Acc-On but you can do it 1 or 2 times more to be sure and if it still dont work you will need an OBD-scanner, or you can go to the garage but its cost something normally
Old Apr 24, 2008 | 11:13 PM
jfink's Avatar
jfink
scratch the garage. a lot of auto parts stores will do it for free. at least around me.
Old Apr 24, 2008 | 11:16 PM
neonracer1010's Avatar
neonracer1010
@$$holezone will do it for free
(autozone)
Old Apr 25, 2008 | 12:23 AM
95to96transplantneon's Avatar
ok i dont know why dark told you to do that but heres how you do it...
ok put your key in... now we havea fewdifferent postions we can move the key to... we can leave the key where it is, we will call this the key in postion... you can turn the key toward you and thats ACC... from the key in postion you can click it forward once, no lights will come on but you wont be able to get your key out... this is the OFF, position. Now we can click it forward one more time, all the dash lights come on and the fuel pump will prime. This is the ON postion. Then there is one more click forward witch will start the car....
Now that you know where all the postions are... try it again...
On - Off - On - Off wait a few seconds your service engine soon light will go off...then begin to blink.seriously it takes like 7-10 seconds to start giving you the codes so be patient.
Old Apr 25, 2008 | 09:40 AM
spudsterier's Avatar
spudsterier
ORIGINAL: DOHCgarrett t3
95's had the service engine loon light....from 96-97 and new it bacme a check engine light
Old Apr 25, 2008 | 01:56 PM
DOHCgarrett t3
wifes car is a 96 maybe its an early model or surplus cluster from the 95's and its a plymouth biggest POS but whatever it drives but the damn CEL light is on and we just had it checked about a few months ago. anyways not a big deal. i used to do the code check with my other plymouth and it was fine. never had an issue with the codes in that one
Old Apr 25, 2008 | 03:51 PM
neoncrazy101's Avatar
neoncrazy101
ORIGINAL: spudsterier
are you sure Spud? both of our 95's have the Check Engine (original clusters). my 97 had the service Engine. till i swapped the cluster into it from a 98. and now it saids Check Engine.
also, my 97 had the Door ajar light. all the other ones only have the little triangle that never works for the hazard lights.
