crank size? need info to replace rod bearings
Old May 14, 2008 | 09:20 PM
cjparker12345's Avatar
cjparker12345
Default crank size? need info to replace rod bearings
what is the diameter of the rod journals on the crank out of a 1997 dohc neon? spun two rod bearings and need help.
Old May 14, 2008 | 09:28 PM
95to96transplantneon's Avatar
Default RE: crank size? need info to replace rod bearings
connecting rod journal diameter 1.8894 - 1.8900 in.
out-of-round max 0.0001 in.
Taper Max. 0.0001 in.
Main bearing diametrical clearance
No. 1-5 0.0008 - 0.0024 in.
end play 0.0035 - 0.0094 in.
