turbo install questions!
Old May 20, 2008 | 08:51 PM
neon527's Avatar
neon527
Default turbo install questions!
i have a 98 DOHC engine w/ Stock SRT4 turbo, wanted to know where would i run my oil feed line , and my coolant feed n return line???? any information would be much appreciated thanks!!!
Old May 20, 2008 | 09:08 PM
I_Ride_Neon's Avatar
I_Ride_Neon
Default RE: turbo install questions!
I used a ebay sandwich kit for my oil feed. But you can use the spot where your stock oil light sensor is. Just T off of it. Coolant. Use your heater core lines. Just get reducers for the lines so the can hook to the turbo.
Old May 20, 2008 | 10:16 PM
das2123's Avatar
das2123
Read this....
https://dodgeforum.com/m_602815/mpage_2/key_/tm.htm
