Turbo
Old May 30, 2008 | 10:43 AM
Blockya's Avatar
Blockya
Default Turbo
I need some help with the oil lines for an srt-4 turbo that is on a 98 2.0 got everything done but need to figure out the oil pressure for this turbo and some advise on the lines and hoe to run them?? Any help would be great!! got the adapter for the oil filter just not sure restrict the oil and have it all fit right. Hopefully somebody has done this and can help with some advise.
Old May 30, 2008 | 08:42 PM
spudsterier's Avatar
spudsterier
Default RE: Turbo
the stock oil pressure works good....if you want more then you will have to get a high volume oil pump.....
i used a stainless steel braided line for my oil feed and a regular rubber oil line for the return
Old May 31, 2008 | 11:09 AM
dtjackten's Avatar
dtjackten
2nd gen neon peace keeper
Default RE: Turbo
basic... oil feed line u can get from ur oil pressure switch, and return run to ur oilpan...
