cant go right
<\\;P>\\;Has anybody had this problem, my 96 Neon suddenly just started dieing, ive changed the fuel pump, filter, auto shutdown relay, and starter relay. now it seems that it dies somtimes when I turn right, or railroad tracks, then after a few seconds turn off the key and it will start right up until I turn right again. every time I try to check it works fine. No check eng lite. any ideas? I was thinking a start switch, but Im tired of wasting money, and I cant find a wiring diagram that shows the run circuit from the switch. ( it is not in the haynes manual )&\\;nbsp\\;<\\;/P>\\;
<\\;P>\\;you might just have a loose wire sumwhere.....or maybe a frayed wire in the harness grounding out over bumps....<\\;/P>\\;
<\\;P>\\;&\\;nbsp\\;<\\;/P>\\;
<\\;P>\\;i had a similar problem with my car....everytime i hit a bump the car would die....ended up being a frayed wire on the back of the motor that would ground out on the head....fixed the wire, fixed the problem...<\\;/P>\\;
<\\;P>\\;with the car running, shake the engine wiring harness...go through the whole thing and see if the car dies<\\;/P>\\;
there is sumthing wrong with the script on the site....the admins are working on it
Trending Topics
I dont know whats up with the script, but my car still dont work "RIGHT" LOL, I did find a post from Feb 08, the exact problem his 96 stalled when he turned right, but he never said what fixed it, now i have the car on ramps looking at wires, under the hood, the dash is taken apart Ive looked there if any body knows "Crakerg" ask him what he found, heat index here is 104 I cant spend alot of time outside this week....HELP
